I have a 2003 Sundance Bahia. The display showed a 356 code when restarted after water change. Tub cycled on & off . I replaced the circuit board which solved all those problems. The tub runs fine now but will not heat. The heater light is on and there is no FL1 or FL2 code flashing. The circulation pump is working fine. Any ideas as to what could be causing this problem?
