I Have been using bromine for a few years. now every time I used the spa I get a bad rash on my body mainly on my arms, legs, and back. I am the only one who get the rash. I have Tried baqua spa I did not get a rash but It casue alot more work and used alot more chemicals then its said. I have Used Nature 2 mineral stick with mps. After a few uses I started to get a slight rash again.
Right now I have been using the dicloro/bleach method and shock with mps. I do not get a rash using this system and I like it. My only problem is I am not able to go and test and add bleach every day and I am just worried about somthing bad growing in there. The local shop says its okay just to put some in before you go in. I just dont trust that. My girlfiend dad uses clorine pool tabs in his spa but every time you open the cover it smells like you in a chlorine factory. I also read some where that it is not good to use.
Can any body recomend a system that you can check once or twice a week and that does not use Bromine and mps as a saniters. ( I can shock with mps)
I decontaminate every time I do a water change and I keep the spa at:
Temp - 104
PH- 7.4
CA- 180
Ta- 80-120
Borate 30-50
cya 25
