I am new to the forum and would love some advice. I have had a Nordic Sport (300 gallons) for about 5 years and recently had to replace the pump after the seals kept leaking (which lead to rusty bearings). I had been using softsoak and in talking to the dealer decided to switch to a Nature 2 cartridge along with Spaguard shock and chlorinating concentrate. With this new regiment, I have been having a really hard time keeping the PH from getting too high. Over the past 2 months, I have dumped in almost 2 lbs of sodium bisulfate. The dealer has not been very helpful and his knowledge seems pretty limited. I seem to be able to get it leveled (according to the softsoak test strips which the dealer said will work fine to test the PH even after switching to chlorine), but within a day or so it bounces right back up. The TA has stayed fairly constant at 125. The spa is kept covered, the aerators are off, and my girlfriend and I use it for about 30 minutes at a time about 5 days a week.
I am thinking I need to drain the tub as I am starting to get scared that I am going to kill another pump if I cannot get things under control. If you don't think I need to refill it, any suggestions on getting things under control?
If I should refill it, any advice on getting things under control from the beginning and a simple regimen for keeping them that way?
Also, using chlorine, any suggestions on good test strips to use?
Thanks in advance for your time!
