Ok, I've poured over all the advice I could find but I'm still lost. I bought a HotSprings Grandee about a month ago with the Ace system. I just received the Taylor testing kit that was recommended on this site and i've done all the tests but have no idea what to do! My FC is 3.6 ppm. My CC is 1. My Ph is 7.7. My total alkalinity is 70. My CYA is 0 (I only added dichlor once the first day and not very much). My calcium hardness is 90.
According to the ACE specs, my TA is fine but my Ph is slightly too high (should be below 7.6) but the PH decreaser says not to use if the total alkalinity is below 140 (or so, can't remember exact number).
When I used the test strips my calcium looked fine but 90 is above the ideal range of 25-75.
I think my FC is fine but obviously the CC is too high. I don't understand how to lower it on an ACE system. And, should I try to increase my CYA by adding dichlor?
Finally, should I use the calcium remover that came with the spa (a filter thing you put in the bottom) for a day or so?
Any advice will be MUCH appreciated. I feel like an idiot right now!
