My husband and I purchased a Hot Tub 9/1/10, since we have had it we have drained it 3 times. Two days after we purchased the Hot Tub one of the motors went bad and had to be replaced, therefore the spa water was not circulating for several days until someone came out to replace the motor (that was the first time we drained the water). About a month later my husband developed a rash all over his body and from reading numorous post and days of research on the internet I deducted it was probably spa itch. We drained the spa again, cleaned everything and refilled it. We use Brilliance Bromine, Oxidizer, and Metal and Scale Control. I also have Ph increaser/decreaser and Total Alkalinity increaser. We test the water daily to make sure everything is at the correct levels. He stayed out of the spa for several days and his rash went away. He started using the spa again and the rash returned, so we drained the spa again and cleaned everything thoroughly yet again. Again he stayed out of the spa and his rash went away, just as soon as he gets back in the spa his rash returns, this time even worse than ever. I am at a lose as to what to do other than trying to switch from the bromine to dichlor to see if that may be the problem. How would I go about switching from Bromine to Dichlor?
This is our regular routine for the spa:(This is what we were told to do by the supplier)
We have a floater containing the Bromine, we keep it on 3.
Once a week I add oxidizer and metal scale control
We also have a Spafrog
We check the water daily to ensure everything is within the correct range, which it always is.
I know this was a very lengthy post, I was just trying to not leave anything out. Any help that you can give us would be GREATLY appreciated.
