Hi all,
I have a pool with integrated hot tub that has all Jandy equipment (filter pump, filter unit, heater, chlorine gen) as well as a Polaris powered by a booster. We don't use the heater a whole lot, only when we use the hot tub. It's run great since new (about 4 years ago), but last night threw an AGC error after heating the tub to about 95 deg. If you reset the heater and fired it up again, it would go through its start up routine, try to heat the water (burners would light and fan would run for about 5 seconds, twice), then it would throw the AGC error.
I read through a few forum posts (that's how I found this forum) and it seems that the official Jandy recourse was to clean the filter or determine cause of pump oscillation. Does this generally mean that my filters need to be cleaned/changed because they're not allowing enough water to flow?
Thanks,
Chris
