Hi Folks, I have a Caldera Tahitian hot tub that has a sub panel with two breakers; one is a 30 AMP GFCI three wire system, which when tripped, kills all the controls to the tub. The other breaker is a 20 AMP, two wire GFCI that I am hoping goes only to the heater circuit. Tub is on 240VAC.
I recently installed a 4KW solar system on my home and will be switching over to a Time Of Use payment billing rate with PGE to maximize the rate I get for producing solar. This also means that I get charged $.40/kWh for power I use during the summer months between 1 PM and 7PM. I absolutely want to minimize my consumption during those times and I don't ever want the tub to kick in to heating mode between the hours of 1PM and 7PM or I pay $.40/kWh.
I found an Intermatic T104R timer that is a Double Pole Single Throw (DPST) switch capable handling 40 AMP resistive load at 120-480VAC. The instructions and diagrams for the switch are here: http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/t104%20-%20english.ashx more details are here: http://www.intermatic.com/products/timers/mechanical%20time%20switches/24%20hour%20dial.aspx
Would you be so kind as to confirm, that the two wire, 20 AMP circuit goes just to the heater and this is where this switch could be installed by a licensed electrician?
The tub does have a summer mode setting which shuts the tub down each day for eight hours from when you activate it. But it also requires putting the temp down to 80 F. If anyone knows how to reprogram this to allow a setting of 104 degrees F, with a summer shutdown setting that would work even better.
Thanks,
Harvey
