I'm looking to purchase a spa later this year (in the south FL area) to have on my outside patio. We would prefer a standard 120V/15A spa, as that would not require any additional electrical work since there is a covered GFCI 120V/15A plug outside already. From what I can find, the only models that are compatible are Jacuzzi J-315& J-325, and Rec Warehouse 'Big Easy' model. We were at Rec Warehouse last week, which carries spas from a manufacture called Leisure Bay, and there was other 110V models (such as the Hilo), but required a 20A outlet and breaker on a dedicated line, which we were told would run about $400-500 to install. The 220/240V with 40-60A dedicated line would be pushing $1200. This was more than we wanted to spend just for electrical work, so the alternative is using a standard 120V/15A spa. The only one there at Rec Warehouse that could use a standard wall socket was this Big Easy model ($3800), and I didn't care for it. It looks horrible and doesn't even have a real water heater, as it uses a 'heat recovery' system from the pump motor to heat the water.
So the other day I went to a local Jacuzzi dealer that has the J-315 and J-325, as both of those can use a standard outlet. Since I had by swim suite with me, I was able to get into the J-315 (yes it did have water in it and was plugged in) and tried it out. It was nice and I liked the jets, but since I'm tall (6'4"), my legs felt a bit cramped on the lounge seat since the water filter was down on that end. I had to sit in one of the other bucket seats to have enough leg room. I also got in the J-325 (but no water in it), and felt more comfortable as there was more leg room down in the foot-well. (I just wish the J-325 had a lounge on one side.) The J-315 was about $5300 and the J-325 about $6100 (installed with cover).
Our target price range was about $4500 at the high-end, but I just can't seem to find anything else. I wouldn't mind having a 220/240V line put in, but not at $1200. So in this situation, are there any other brands & models of spas that are good quality that can work in a standard 120V/15A outlet? Suggestions are welcome!
