Hello, all. New to this forum and in need of guidance. I have inherited a tub from my father-in-law and want to hook it up in my backyard. The concrete patio is about 3 inches thick where I will put it. It's an 8 ft. octagonal tub with dual 220V motors, natural gas heater and DE filter system. I don't need the commercial duty gear, so I am going to get creative to save space and make things easier to maintain.
I plan to convert to paper pool filters and need to figure out how to best wire up the motors/pumps for my needs.
Would it be sufficient to use one, 110V electric pump (1" line) that flows 750 GPH for my sanitation pump? I would use a T fitting at the skimmer output to feed it, so it would always have water and not have priming issues. It would connect back in to the main intake a couple feet further down with an anti-reversion valve on the main, so it doesn't back flow into the tub. Would that be enough to keep the water stable and clean, running for say 1/2 hour every 2 hours? How many times an hour/day should the sanitation pump be exchanging the tub water?
For power, I would like to use my dryer circuit from the garage. The circulation pump motor is 220V and 9.2 amp (18 A counting for both legs). Heat will come from a natural gas heater. I have all the electrical from the tear out of the tub as well, including air pressure relay for jets, GFCI and timers. I intend to buy some 10-4, run dedicated ground for the dryer circuit and connect the 220V GFCI for the circulation pump. I was told by a co-worker with pretty good electrical knowledge that I could break out one leg of the 220V power, to create a 110V plug for my little sanitation pump. Would the GFCI protect the 110V circuit as well?
Thanks in advance for all helpful suggestions.
Jose
