Hi,
The ground in this area is "Marl" or clay based. All pool builders that I spoke with have an extra charge if they have to control water...meaning...if they dig and find underground water, they will have to use stone/gravel or build a French drain or a similar process to control the water so that the pool base does not crack. In my case, the pool base has cracked 3 times and in each case, immediately after the repair was made, a crack develops in the same area. They now tell me that this is normal and since the most recent crack is relatively small, that it should be fine. The pool is open and we are swimming(vinyl liner covers the crack) but I suspect that the crack will grow in size over time, just like the others did. The final payment for this project is due upon completion and all work is warranted for 3 years; once I make that final payment...I suspect getting any repairs made will be like pulling teeth.
Construction began in April/2010 and in my mind, there should be no cracks in a brand new pool.
Thanks.
