The 3 port valve on the Spa-Pool is 15 years old, but it looks like the current Jandy 4717 2 to 2.5-Inch Positive Seal, 3 Port NeverLube Valve
Anyway the "inners" including diverter, O rings and top have been replaced. I looked at the valve walls and the molded plastic bushing in the bottom, they seem to be in good shape. I coated the diverter in MagicLube. The valve is not close to a heat source that would cause it to warp. Has anyone replaced the "inners" and still have a Jandy Leak?
The latest local Technician reccomendations is to put the Aqualink in service mode, fill spa, and then put in spa mode.
Wait overnight. If there is no leak, then it must be the spa return check valve (which has already been replaced)
Does this Forum agree with this test?
How well does the Jandy 3 port seal for an elevated spa? This is a slow leak (spa leaks roughly 2 inches in 4 hours)
Thanks in advance. Escrow closes August 20th---Help!
