Thanks for the information.
My test kit only goes up to 2.5ppm for chlorine.
How do I measure huge amounts like 12 or even 20ppm?
I have about 20 kids coming over for a birthday party today.
How much bleach can I "safely" add before the party (in four hours) so that I don't have kids complaining about burning eyes.
Bleach IS chlorine, specifically sodium hypochlorite. No different than the liquid chlorine sold for pool use and in many cases exactly the same strength! Pool chlorine is usually 6%, 10%, or 12.5 %. Bleach is 6%, 5.25%, or 3%. If you go the bleach route get the 6% or 5.25%. It is an unstabilized chlorine (same as cal hypo and lithium hypochlorite) so it will not raise CYA. I would stop the trichlor right now with a CYA level of 60 ppm or you will be asking for trouble. Ditto for dichlor, often sold as shock. Cal Hypo shock is fine but mure expensive than bleach and will cause calcium levels to increase.
With a CYA of 60 ppm you want to maintain your FC at about 5-8 ppm at all times. When you shock you need to shock to 20 ppm. I suspect that you are not keeping your FC up there and have a constant nascent algae bloom consuming your chlorine. The fact that the only chlorine in your water is 1 ppm CC (TC-FC-CC) supports this. CC should always be below .5 ppm!
BTW, three gal of 6% bleach would only raise your FC by 14 ppm in 13.5k gal and 5.25% by 12 ppm, hardly shock level with a CYA of 60!
