I purchased a Sundance 800 series spa that is in excellent condition. The only known problems are a lot of wood rot around the trim and part of the frame where it was sitting on the concrete pad and exposed to weather. There is also some sort of ultraviolet device that filters the water that I'm not sure is working or not. The "fizzy" jets are not functioning. Everything else functions perfectly and the tub itself is in immaculate condition. I am documenting the moving, installing and restoration of it on a flickr set. Would love any advice or information that you could give me and please don't hold back. I want to know what I'm getting into. And I purchased this from a family member for nearly nothing which is the biggest reason I took on this project.
Here is the process I'm currently going through to get it moved from its current home to it's new home:
I have 5 strong guys, a ford tractor with front end loader that can lift up to 1200 lbs and a dual axle trailer to set it on. Our plan is to raise each side of it, place 2x4's under it to get it off the ground and then slide some straps underneath it to lift it. The tractor will lift it and we will all walk up the hill with it and keep it from swinging. We'll set it on the trailer and transport it to it's new home.
At the new home, I am in the process of prepping an area in my deck with paver stone footings on top of sand. I'm going to make sure it's all level. I am cutting a space into my deck and will recess it into the deck.
Now, for the first question. Do I need to worry about trim on the sides that are recessed into the deck? If anything, I could just nail some OSB to the frame where it's recessed and trim out the exposed areas?
Any recommendations where I can get some replacement trim, especially on those rounded corners?
I think that's all for now but I plan on keeping this thread updated. The moving of the tub should take place on July 25th and I'll be taking plenty pictures of the progress.
Thank you for your contributions.
