We are making some great progress. I added the muriatic acid first, since I was able to get to the hardware store early and the pool was clear in about 5 minutes. Now i am back home again and did a quick vacuum, which stirred up more white particles and cloudiness than anything, but at least i can see the bottom to be able to know...lol I have added 0.5lbs of chlorine reducer, waited about an hour and took a full set of readings again, and here are the results:
(same drop test kit I used last time)
TC: 1
PH: 72
TA: 100
TH: 240
CYA: 90
I also used a dip stick hth test strip that tests for FC and it showed 0 (probably not real reliable) But If need be I will take a water sample by the pool store to get a better test done on it as money is tight to buy a nice expensive test kit right now.
After stirring up the pool bottom it got cloudy again, but I have a feeling it will take a couple of vacuums to get rid of that, and looking at the tests I now know it is safe enough to get in the pool to do the vacuum so that will be much more productive. I am also vacuuming to waste so as to not send it back to the pool again.
Let me know what you think, and where to go from here so i can keep the pool clean and chlorinated. I have always had a problem keeping the chlorine in the water, but now that I have added cya (didn't know I needed to until all of this) I have a feeling that wont be such a problem.
I also want to thank you for all of your help, I wish I had come here before adding any chemicals to the pool as well as bought a decent test kit so I knew exactly how much to add.
