The pump was changed a couple of years ago. However, at end of last year season, the heater was no longer turning on and pool temperature dropped. This year I found and replaced a faulty pressure sensor, replaced the thermocouple\pilot assembly as well. Heater works fine now except for the moaning and groaning. While working on the heater, I was draining the lines by removing a spring loaded device bolted on to the side of the heat exchanger (probably the thermostat device??). Does the device have a preferred orientation, could be mounted either way? The heater is a MIN/MAX unit. How do you determine if that is faulty?
