Thank you, I will try, #8 wire goes from Main Panel to 50Amp sub-panel. Been that way for ten years. From 50amp sub-panel to spa control panel total of six wires. From the 30 amp side #10 wire Blue to T2, red to T4. That goes to Watkins heater #73790. Thats the one that loooks like 2 silver tubes. From the 20Amp breaker is #12 wire, Blue to T3, white to t6, red to T5. a #8 GROUND WIRE GOES FROM SUB-PANEL TO t7 GROUND. Heaters were relaced as follows, original 0ne burned out 11/03, was replaced with 72797. That one burned out 3/06 was replaced with 73790. Both were replaced by a Hot Springs Service tech. So at least he said they were burned out. That one is the current problem. However, as I write this the heater is now working. I do not know for how long. I simply removed the three wire that goes from the heater to the control panel as someone suggested to do and turned the breakers on. This time they stayed on. Now I'm really confused. Any suggestions????
