Just completed our pool and started it up for the first time this weekend. Have a Jandy eFlow pump (var speed) 1.5hp,Jandy cartridge filter, Lxi heater and Aquapure 1400 Cl generator.
As suggested by the pool installer, put the system on Boost to shock the pool at startup. Throughout the 24 hr cycle, I got intermittent low flow messages. Tried using the var. speed adjustment and got flow back when the pump was cycling at 3000+rpm. When it went to a lower level, got a low flow. Still getting intermittent low flow messages and cell reversing message. Salinitiy is 3.0, temp 80F.
Chlorine levels are ok at 1-3 ppm but I concerned that I will need to run the pump at above 3000 rpm all the time to generate the required amount of Cl. I was hoping to be able to cycle it down part of the day to save on energy.
Any thoughts about this problem? Is this a pump issue or a cell/sensor issue? I am getting good flow to the pool at lower rpm's but am thinking the flow isn't sufficient for the min. cell requirements.
Any help/comments would be appreciated.
