I have a similar problem with my rs6 to those being posted here...
My pool cleaner (booster pump) cycles itself on and off every minute or so. This just started happening randomly. I've cleared the indoor Rs6 memory using the system tools clear process (which removes all schedules) and run the diagnostic process which says everything is ok -- and I still have the problem. Even when everything is off, the cleaner will turn on for a minute (or a few seconds) and then turn right back off. The weird thing is that if I run the override at the control box outside, I can get everything to work just fine. It is only when the manual override mode is off on the external control until that I get this weird behavior. Has anyone else seen this weird on/off cycling behavior and fixed it?
