Hi all,
I have a Marquis Recreational spa that I've just moved to a new house. At our old house we had the unit wired for 240V permanent installation. At the new house we don't have a 240V connection and don't plan to have one installed for a few months. I'd like to convert the spa back to 120V temporarily until we have the new 240V service installed. I followed all of the instructions on the Balboa wiring diagram to convert from the 240V settings back to 120. When I plugged the spa in the pump ran for a few minutes and then the motor tripped out. This led me to believe the motor internal wiring needs to be changed back to 120V also. Here is the problem: We had a reconditioned pump put in a few months ago and there is no wiring diagram or data plate on the pump to go by. The pump is a 2speed GE unit, and I am almost positive the unit is dual voltage, but without the wiring diagram I can't tell.
Under the wiring cover the following are connected:
Terminal "1" - Neutral (white wire) from controller
Terminal "2" - Low Speed (black wire) from controller and blade connector with black wire to motor windings
Terminal "3" - High Speed (red wire) from controller AND blade connector with blue wire to motor windings
There is also a red wire connected to a blade terminal below a label B A
Can anyone help me convert this motor back to 120V? I've attached a picture of the wiring on the motor side. Thanks everyone.
Will
