Hi - I am wondering what sort of controller I should look at adding to my pool system. Last year I didn't have the variable speed pump, so just turned the pool heater on in May and turned it off in October. I ran the filter for about 5 hours, set the heater thermostat to 85 and forgot about it. Now with the added variable pump I have a lot more opportunity to save some $$$ on gas, but think I need to have something to control the heater if I want to get the most energy savings.
Here's the equipment list and what I would like to do.....
Pool Pump & Controller
- Hayward Tristar Energy Solution Variable Speed Pump Control
- Hayward SP322063EEV 2.7 THP 3 Phase pump
Pool Heater
- Sta Rite Max E Therm SR400NA
Filter
- Pentair Clean & Clear Plus CCP420
Pool Sweep
- Polaris 380
Pool Sweep Booster Pump
- Polaris PB4 3/4 HP
Pool Sweep Timer
- Standard 24 hour dial
Pool Details
- 27,000 Gallons, 40' x 15' x 3-8', Gunite in-ground rectangular(ish) pool, no spa, no cover, Northern California
Requirements
- pool heated May thru October
- pool temp 85 degrees Fri/Sat/Sun afternoons
- pool temp 75 Mon/Tue/Wed/Thu (this is to avoid wasting $$$ heating a pool that's not being used in the week)
- ability to easily (i.e without complex reprogramming) get pool to 85 on Mon/Tue/Wed/Thu with one-day's notice
- doing this remotely would be a nice feature, but not mandatory
- pool sweep to run in the morning
- no significant pump noise during afternoon (i.e. pump on low setting only)
- easy winter setting (i.e. filter, sweep but no heat - Nov thru April)
thanks, Alan
