Hi,
I am pretty new to swimming pool maintenance but I like to dig into things and it just so happened my 1hp pool pump died a couple of days ago...it is probably the original in the pool and I can't even tell what company manufactured the pump. I figured this day would come and decided to wait until it died before replacing it. The label is so worn that the sf is worn off so I really don't know if it is a fully or up rated pump...I am guessing just a 1 hp due to the age.
I recently added solar to the pool about 2 years ago. The solar company said my pump would just barely do the job and for the past 2 summers it heated the pool fine. I have a tri-level house so there is significant distance from the solar collectors to the pump ~70 ft total distance. I did research on the net trying to determine the optimal pool pump for my pool and based upon my calculations it appears to be a 1.5hp pump. The pool itself is a pool/spa gunite and has 1.5'' pipes and probably 30 years old. I currently have a booster pump for the pool sweep, not sure on the hp but I think 3/4.
When looking at replacement 1.5 hp pool pumps they all seem to be 2'' inlet and outlets...will having 1.5'' inch pipes cause excessive wear on the pump due to the limitation of flow rate? All the pipes for the solar, filter and gas heater are 2''.
I am currently looking at purchasing the following medium head pumps. (at least I think these are medium head pumps)
1) Hayward - SP2610X15 - Super Pool Pump | 1.5hp (SP2610X15) - I believe this pump has 1.5'' inlet and outlet.
2) Sta Rite MPR Series - Dyna Glas Pool Pump - Up Rated | 1.5hp - STR-MPRA6F148L - obsolete but I think I found a place on the net that has some in stock, havent actually called them to verify.
3) Pentair Whisperflo Pump Up-Rated EE 1.5-HP WFE-26 - 115/220V - (011518) - 2'' inlet and outlet
Any advice on which pump I should purchase with regards to price, reliability, energy efficiency? The hayward is about $50 cheaper than the sta rite and the sta rite is about $50 cheaper than the whisperflo. If you have a different pump than what I listed please mention as I am not locked into the above pumps.
I plan on selling the house within a year or two so I don't want to break the bank on a new pump...I was thinking around spending $500 or less if possible.
Thanks,
Chris
