I am unsure of what pump or blower is what, so anyway here goes.
Facing the controller the motor to the left is stuck on. I suspect the relay is fried and plan to replace it.
I am unsure what voltage the motor runs at. It has three wires, a black, white and green, 120 VAC?, the motor has a tag indicating it is 220. I plan to pull the plug at the controller and meter it.
Prior to the burnt motor relay the heat ran away. We used the spa one night and the next day the spa was 118 as displayed. It was very hot. Do I have another problem here with another fried relay? The lousy owners manual indicates there are safeties that will not allow this to happen. This is why I believe I have another burnt contact. Obviously I will meter this output also.
I plan to verify what voltage the motor on the left is and hot wire it. I will then see if the heat will come on, via the top level display. If it does not I then suspect the entire board is toast.
Additionally the pilot duty on off switch on the side of the control panel no longer has any effect on anything. (fried motor and heat relay?)
Is it worth my time to R&R the relays? Or should I assume the board is toast and attempt to order another one?
I have searched and cannot locate any electric or plumbing skematic of this spa. The manufacturer has not returned my email request for service.
Thanks in advance
The model is as follows
Hydro Quip
Charisma
PMHPTBC - 240DPEP
220 VAC
Gecko Controller 9911-500132 Rev e
