Thanks again for the replies. I did verify that it is a 240 V circuit using the multimeter.
I went out to buy wire today.
There seems to be some ambiguity around the need for THWN versus THHN wire.
Lowes, for instance, had mostly THHN. They only had 1 THWN, which was 14 gauge.
I was wondering is it OK to use THHN instead of THWN.
I've read on some sites that they are basically one in the same these days. Is that true?
The THHN at Lowe's doesn't say anything on it about THWN.
Also, should I stick to the same wire thickness that the pump uses even though the Aquarite draws very little current?
The pump is using either #10, or #12.
Do you think I should use the same for the Aquarite?
Also, should the ground be the same size wire as the hot wires?
Lastly, I was wondering exactly where I should bond the Aquarite to? Would it be ok just to bond it to the circuit box?
I can't tell exact where the pump bonds to. It's bond wire goes along the ground towards the circuit box, but then disappears underground. It is not encased, which I'm assuming is fine for bonding.
