We just had our new Maax 470 delx series Spa delivered yesterday, we live in Tucson, AZ.
The Spa was an empty never filled floor model, and they took it out of building afternoon before delivery date, so it was sitting outside overnight. There was water (like 1 gallon) in wells of seats, I asked the deliv guys how this happened and they said their was frost on it this morning since it sat outside overnight. They set up the spa and there is a leak (lost 1/2in from 2PM yesterday to 8AM today). I turned the spa off, it ran through a 2 hr filtration cycle and was heating throughout night- since the set up guys left it like this- even knowing it was leaking, they could not find the leak (there service dept is coming out today to look at the issue). Does anyone in repair business think that even though there was not a freeze the night it sat out, that it could have had some type of damage due to cold weather (38degrees)? Also the set up guy said there was about 1/8 in of water on bottom of interior at 2PM yesterday (they closed it up so don't know what it is now), there is not a full blown-in insulation on this tub, but there is a little sprayed in around the base of the tub and a reflective like insulation material on the bottom of tub cabinet (inside that is) then the tub shell itself has insulation foam (thin layer sprayed on it) the water may be touching the bottom portion and I read on here something about this effecting the R value. Does anyone think I should just ask for another tub, or is the tub going to be fine if they can find and fix leak easily. ALso if they find the leak and fix it should we keep tub turned off and leave the side panels off for a day or two to let this tub air out and dry or should we close it up to protect from cold weather (no freeze expected just cold).
We bought it from a local company - Patio Pools and they are having a service guy come out, but not until 1-3PM today.
Side Note, all jets and pumps and controller is working fine, well except for one jet, that we didn't notice until after set up guys left.
Moe
