Hot Tub Set Up & Water Issues
I have a Snorkel cedar hot tub with well water and an ozonator. For years I was using chlorine with Nature 2. When I would first add the water to the tub, it was clear. Then, when I'd add the sanitizer, the water would cloud up to a brownish color. I would then add a product called Metal Free and the water would clear up.
For the last year I've been using Clear Water Blue in an attempt to not use Chlorine or Bromine. Clear Water Blue also clouds up the water with a brownish color - except the manufacturer has informed me that I cannot use Metal Free to clear up the water. Clear Water Blue requires daily shocks which bring about wild swings in the PH and alkalinity and need daily attention. And, unless I shock it with chlorine periodically, the water eventually develops a musty smell.
I've attempted using an Eco-One Pre-Filter and while it helped some, the problems still persists. The Eco-One vendor suggested I have the water tested and possibly get an iron reduction filter. The water was tested and was found to have a high iron content. A local water treatment vendor recommended a Pentek RFFE20-BB Radial Flow Iron Reduction Cartridge.
Questions
Any suggestions on the following:
A non-chlorine/bromine sanitizer that would work well in the above situation?
How to maintain clear, fresh smelling water with well water and a high iron content?
Any recommendations on the Pentek RFFE20-BB Radial Flow Iron Reduction Cartridge?
Any other suggestions?
Thanks.
