pipes51
pipes51's Achievements
  1. i turned off the breaker, no other slimey crap. there is plenty of water, its above the line. how do i adjust the pressure sensor?
  2. no dice. I do notice that it will get a few degrees warmer when the weather gets warmer. This weekend it was 70 and it got up to 94. what now
  3. I'm not a patient person so with the filter still out I'd run the jets on high to make sure there's no 'crap' in the lines then shut off the breaker and turn it back on.
  4. I pulled the filter, it looked like it was full of a bunch of slimey looking crap. the light did not come on. Do i need to run the jets or just let it run in the filtering mode. it constantly runs all day anyway. thanks
  5. Is your heat indicator light on - on the top side control panel? No , just a green light by saftey suction.
  6. All of a sudden my spa will not heat abouve 90. The only thing i can remember i did was take a screw out of a drain looking thing in the bottom because the little cover was broke and i didnt want someone stepping on the screw. That shouldnt affect anything ahould it ? Let me know if you have any ideas. Thanks Its a 2000 cal spa i believe.
