I guess I am also a newbie since I haven't figured out the chemistry. 400 gal Hot Springs Vanguard came with house purchased in 2006. For 3 years we enjoyed it, just used test strips to keep FC, pH and TA in recommended range. I've just had to replace the cover and lifter, and since I now have several hundred $ invested, I decided I would buy a Taylor K-2006 kit and do things right. Kit arrived about a week after refill. Measured levels at that point: CH=40, TA=50, pH=7.9. I first used Leisure Time Calcium Booster, aimed for CH of 150 but ended up with 170. I then focused on getting TA up, so added 4 oz sodium bicarbonate (SpaGuard Total ALkalinity Increaser). At this point I measured CH=170, TA=100, pH=8.0. I did the Taylor acid demand test, which said I needed 0.7 oz dry acid to get pH down to 7.5. I added the dry acid (using SpaGuard pH decreaser and measuring with a digital kitchen scale with 0.1 oz resolution), ran all jets for an hour then let sit for an hour. Remeasured pH with Taylor kit and got 8.0 again. I repeated this 3 times, with same result, no change at all in pH, although TA measurement was dropping. Taylor acid demand called for 0.7 oz dry acid to get down to pH=7.5, but adding this much gave NO CHANGE in pH reading. After 4th addition of 0.7 oz dry acid I finally got to 7.9. Three more cycles of adding dry acid I finally got to pH=7.7, this time I added 0.4 oz dry acid. Next day pH reads 7.9 again, with TA back down to starting point of 50 ppm.
What is going on here? I started with pH=8, I have added 5.3 oz dry acid, incrementally over 3 days, pH is at 7.9. While the saturation index is pretty low with these numbers, that pH value seems pretty high.
For the record, I am using Nitro's dichlor/bleach sanitation procedure. My CYA measures 30 using the Taylor K-2006.
Should I be doing something different, or should I live with pH values that high?
