Before I go forward with an expensive support call, I wanted to see if anyone else may know what is going on with my tub.
The heater works fine, but randomly every couple of weeks, I will get the dashes on the display indicating hi limit tripped, and the heater will be shut off, while everything else works.
I have replaced the filter, replaced the hi limit sensor, both with brand-new parts and it is still happening.
I have taken the heater relay board out to inspect, and there are no obvious flaws to me and I had also checked all wiring with a multimeter (to the best of my ability - not an expert here), but 240 is going to the heater when it is on.
So, does this sound like a heater relay board problem, a main board issue, or is this something else?
Edit: Turning power off and then back on will immediately fix the issue for days to weeks until it happens again. Circulation pump seems fine as the circulated water output is strong.
