If the temp seems harder to move it is sign it is giving out. The above poster is wrong Balboa did not stop making them.http://www.horizonparts.net/store/main.aspx?p=CategoryItemListBody&c=COPE#COPEBA
here is a link to topside controls look at the manufacture number for the one that looks like yours. This company does not sell to the public, but at least you have a part number. If all fails go to www.balboawatergroup.com for a phone number and they can also help
I tried removing the temp sensor (not high limit sensor) and it was stuck in the sensor mount.
I cut the wires at the sensor and drained enough water to remove the mount from the hot tub.
The sensor mount was so filled with corrosion that the sensor would not even twist in the mount.
(The mount is made of metal rather than plastic or nylon and was corroded all the way through).
Anyway, I have no doubt that I found the trouble.
I put the housing and the sensor in a pan of water heated it up.
Using my Simpson ohmeter, the resistance didn't change going from 50 degree water to 110 degree water.
Now I have to find a new housing and temp sensor.
This is what I need...along with the housing.
http://www.hottubworks.com/part-B30352-ite...-spa-sensor.php
I'll just solder it back to the original wire that were cut.
Thanks
