Hello all, I am hoping you can help me out.
I have a CalSpas above ground spa with a multiple speed 5BHP pump. I just rebuilt the wetend and reinstalled the pump because the motor had the infamous hum and didnt function. Reinstalled the pump last night, filled the spa, gave it power and I hit the Jets button to see if everything was functioning. VIOLA! It worked. FYI this was the first time Ive ever done anything myself on the spa but I am mechanical.
Later that same night I went to check on it to see if it was heating up, nothing. So I hit the jets button and the lower level of jets were the infamous hum again but the higher level of jets worked. I called it a night. This morning the temp was set for 90 EC which means heat to 90 degrees and maintain it within 10 degrees give or take (maintenance type setting for when not in use). So it did heat up over night. I hit the jet button, viola! Oddly though now I only have off and on for jets (I could be mistaken but I swear I am supposed to have 2 speeds of jets). So I decided to test the heat and set it to climb to 100 for use so it should maintain that temp within in a degree or so give or take. Now the pump keeps coming on about every 5 minutes and only hums for 10 seconds and stops. I have bleed the line by loosening up the input line to the pump and draining any air, rebuilt the wetend as previously stated. Now I am at a loss, anyone?
