I have a Hayward C1200 cartridge filter with a AO Smith USQ 1102 motor married to a Sta-rite Dynaglass pump. Yesterday I replaced the old filter cartridge which had an operational pressure of about 30 psi after deep cleaning. Before draining the Hayward I closed the skimmer valve (the only one opened) and closed the inline chlorinator. After replacing the filter I turned the pump on then walked away for about 1 minute when I realized I hadn't reopened the skimmer valve. I did that immediately and got water flowing. It took longer than usual for the air to bleed out of the relief valve on the Hayward. Also, the pump motor is a little louder and rougher sounding than normal. The operational pressure is now about 3 psi. In addition to the increased noise I've been going out about every 15 minutes and bleeding more air out; it just keeps building up. The motor is less than a year old and the seals were just replaced last week (a small rock destroyed the impeller and seals). After the seal/impeller replacement the motor was pretty quiet.
I'm guessing the noisy motor and increased air build up is a result of running the pump dry for a minute. Is this anything I should be concerned about? Why would it continuously build up more air in the Hayward? Any advise greatly appreciated.
Tim
