I have a sand stone pool. There are two waterfalls, one large one for decoration and another one off the spa. I have had two problems with the stone:
1. Lime build up on the stone
2. Sand in the pool when we run the fountain
It has been hard ot find info on how to care for this, so I am posting my experience in cse it can help someone else. First, to get rid of the lime I first started with a 50% dilution of muriatic acid. Spray it on, it will not harm the stone. Let it sit for a few hours, then rinse of. You will need to work on the heavy build up wit ha wire bruch or razor blad after, but it comes off a lot easier after the acid wash. The acid will also take care of the thinner stuff without any additional manual labor. Then I went back and acid washed again followed by pressure washing. Afterwards, it was 95% free of any buildup.
To retard the additional development of lime and to keep the stone from eroding sand into the pool, I used Deck-O-seal's deck-o-shield, and you can find the info here: http://www.deckoseal.com/783a.htm
This stuff is AWESOME. It went on easy, great coverage, abnd you could see the water just bead up on the stone after. I ordered one gallon that was enough for all of my stone, which is alot. Highly recommend it.
My only problem I still have is from the prior owners poor care. I do not think they EVER resealed it and there was some erosion of the mortar at the spas waterfall. I have some water penetrating somewhere into the stone and coming out elsewhere. I do not want to do a major job of removing and remortaring, as I am afraid the mortar will look different. I did the best job I could by filling in with 100% silicone behind, but it didnt work. Any suggestions would be appreciated.
