billydee
billydee's Achievements
  1. Hi Quantum and thanks for the help. She put in ph Up as it was on the low side, ph Plus, hth Regular chlorinator to shock it and also Stabalizer and conditionor. She also tried liquid clarifier. The chlorine level reading says that the level is fine. How much bleach do you think we should add and I assume you are talking regular household bleach and not the granules? Thanks.
  2. Hi, new guy here. We bought an Intel pool and have had it set up for about a month now. We use a solar blanket and it catches debris from falling into the pool and it is quite clean. However, there is a yellowish residue that settles on the bottom and we have tried to vacuum it but it seems to be passing through the dirt container on the vacuum and makes it way back into the pool and I am guessing it is very fine. My g/f feels that it is a chemical and said she noticed it after putting the chemicals in. She checks the readings every other day and is satisfied with them. Any suggestions? Thanks in advance.
