Thanks for the quick response Pool Clown! I did what you said and received a 172 and a 186. I checked the chlorine with test strips and it was virtually non-existent(bad sign?). I also removed the flow sensor and cleaned it with a scrub pad(it wasn't dirty though) I also cleaned the cell with muriatic acid but it was pretty clean as well. After all that I still have the codes and general fault/check aquapure. The pool was completed in May of 2007 so the aquapure should still be under warranty. Should I start with the pool company that installed the pool or go direct to Jandy/Zodiac?
I've added some chlorine tabs in the mean time. I'm in Houston where the temps have been in the 100's for about 3-4weeks with NO rain. The pool is always around 95-96 degrees, could that have any affect on the system?
