Hello Folks and thanks in advance for any useful advice-
I have a 25,000 gal. inground concrete pool. My system consists of a 1.5 hp pool pump, a Jandy AE 2500 pool heater, and a D.E. filter. I am having my pool drained and resurfaced using marble dust in the near future. I thought this might be a convenient time to switch to a salt water chlorine type system to perhaps lower my chemical costs in the long run. However my knowledge of this system is quite limited. I have some questions that I would like to pose. Here they are:
1. Will the salt water system affect the life of my heat exchanger (titanium) in my heat pump?
2. Will there be any corrosion issues on other parts of my pool filtering system as described above?
3. Will the salt water system affect the longevity of the marble dust coating on my pool walls?
4. Is it less expensive to operate in the long run than using chlorine?
5. Do I still need to add the same chemicals ( i.e. calcium chloride, sodium carbonate, sodium bicarbonate, cyanuric acid) as with the chlorine type sanitizing system?
Any other advice or possible tips would be greatly appreciated!
Thank you
