It appears to actually be dripping from the bottom of the plastic housing and not where the braided hose connects to the nipple. I didnt know if there was a user service-able oring or gasket that could be replaced.. (aka something simple)
Hi, I have 2004 Sundance Cameo and it has a leak. The leak only occurs when the pumps are turned on and it appears to be coming from the bottom of the heater manifold. (The thing bolted to the right of the service panel/circuit board)
Does this mean I need to replace the whole heater? or can this be fixed?
Thanks in advance.
I have a 2004 Sundance Cameo with the Sunzone CD ozonator. There are no bubbles at all in the hot tub when the circ pump is on. I think it's time to replace the ozonator, especially since it is 6+ years old. A couple of questions..
1. I can't seem to find a replacement. The part # 6472-651 doesn't return anything on google. Can anyone recommend an ozonator to me please?
2. Shouldn't there be bubbles even if the ozonator isn't working? Would that mean the tubing is clogged?
3. Any other suggestions to troubleshoot?
Thanks in advance
I had the same problem 2x on my 2003 Cameo.. Sorry, but I can't remember if it was a bad sensor/board/pump as the dealer just came out and fixed it both times.
It would show 112, but the tub was really like 98.
Hi,
Our cover and cover lifter for our Sundance Cameo need to be replaced. Where do you guys recommend? I've looked at spacoversasap.com and rhtubs.com. Any experience with either? or any other site?
Thanks in advance
Jason
