I keep seeing about wet testing but its always one with water and its always the 6-7 seater, I did wet test a big size but thats not the model im buying. The Bullfrog is nice, but for me, the one you stretch out in was to small for my left leg and still use the left leg jets, other than that it is a nice spa. I will check out the marquis spirit, see if anybody close sells it.
Keep the info coming,
Thanks again,
Rick
I have a 8 year old jetsetter and it works perfect and still looks as good as when they delivered it. I would say jetsetter
I've had two Hot Springs, one Classic and my current Jetsetter which is about 12 years old. No problems, just one heater replacement. With that type of reliability and my personal experiences, I am biased toward you buying the Jetsetter. Good luck with whatever you choose, Randy
The Bull Frog tub is one of the better designed hot tubs I have found out their. With the options of the jet paks and you able to pick if you tub is going to be a 10 jets or a 40 jets, as well as upgrading a bullfrog down the road. Once you have a bullfrog you can buy new jet paks down the road and have a tub now with waterfalls on it or have your tub have neckjets. These all come on the jet paks. Any other tub you have to trade it in to get these features added on. The bullfrog even has that capablity with a stereo. Most hot tub companies have the speakers pop up from the tub. With the bullfrog you can buy a door with the stereo on it and plug one wire in and your done. This spa is the type of spa that will last and you can upgrade to keep it fresh. The bullfrog was designed by a service tech. that has been in the industry for many years. It's built smart. All the manifolds and most of the plumbing lines are on the jet paks, which make any repairs simple or if it does leak, it leaks back into your spa, unlike other tubs were it will leak empty. And yes their is a hose that shoots water in behind the jetpaks to keep the water moving and clean.
