I am a newbie to this site. I found this forum after searching for answers to my water balance problem. I have been working with my Pool Stealer-ship to no avail. The only thing positive from my partnership with the pool store is their profits. Wow, I actually feel better now...on second thought.... Okay, here goes.
We have a 20' x 40' (35,000 gallon) plaster (Grey bottom) pool with an auto safety cover. Oh yeah, the pool is four years old. Two weeks ago I pulled the cover back to check the status of the water. I noticed (no lie) thousands of fishing worms on the bottom. The pool water smelled like rot and was very cloudy. I decided I better open the pool and get them out of there. After removing the worms and decaying vegetation, I double shocked the pool (six 1lb bags of Calc Hipo 53% shock). The pool water said is that all you got. Actually it was...I did not have anymore shock. I tested the free chlorine level with my handy liquid tester (only tests Ch and Ph) and the level was 0. I took a sample to my pool store and the levels were.
April 27
FC 0.0
TC 0.1
PH 7.6
Hardness 300
Alk - 189
CA - 5
The pool store told me to add 6 3" tablets to the skimmer, add 1/4 gallon of Muriatic Acid, 8lbs of stabilizer, and triple shock the pool. Of course they were nice enough to sell me the chemicals right there (w/ a smile). I added the chemicals, tested the water about 30 minutes later and registered 0.5 ppm of FC. I took the sample to the pool store the next day. The readings were:
May 1
FC 0.4
TC 1.6
PH 7.3
Hardness 200
Alk - 188
CA - 40
They told me to add another 1/2 gallon of muriatic acid and calcium. I added no shock. The readings following this chemical add were.
May 3
FC 0.0
TC 0.6
PH 7.0
Hardness 290
Alk - 180
Phosphates 300
CA - 40
They tested for Phosphates this time. I was told to add another 1/2 gallon of muriatic acid and PhosAway (it should be called wallet away). They also told me to shock the pool. Instead of using the bags of shock. I decided to use Walmart 12% ultra bleach. I purchased 12 gallons. After adding 6 gallons initially, my FC was at 1.5 ppm. I kept adding bleach hoping my FC would get to at least 10 ppm. I added the remaining six gallons and the FC made it to 3 ppm. By morning it was down to 0. The readings after this round were.
May 8
FC 0.0
TC 0.1
PH 6.7
Hardness 270
Alk - 140
CA - 45 (increased due to adding bleach (i assume).
Today 5/8, they told me to add yet another 1/2 gallon of muriatic acid and a concentrated algaecide. I forgot to mention that I have 10 (ten) 3" tablets (Trichlor) in my skimmers.
I am at a loss as to what to do. I am tired of the trial-and-error my pool store is putting me through. Its good for them and I think I am helping keep them in business during the recession.
I have two main issues:
1) My Alkalinity won't drop. Now my PH is on the very low side. Could the unstable chlorine issue be causing the alkalinity to be resistant to change?
2) Why won't the pool accept chlorine? I read on another forum that I should add 2lbs of shock per 5,000 gallons of water to get the FC over 10 ppm. This would equate to 14 bags for me. I have only added a max of seven (thus far). I have 15 bags, but did not want to add them (for nothing).
I would greatly appreciate any thoughts, consultation, or recommendation on how to correct this problem. I also accept sympathy.....
Thanks a million.....
