You sir are very astutue and clearly know your pools. I only wish that I would have checked the posts yesterday afternoon. It would have saved me some headache (see below). I actually sort of figured that out on my own before seeing your reply. I noticed the other actuator and the switch that indeed was in the OFF position.
I had replaced my old DE filter with a sand filter about two weeks ago. I must have inadvertantly hit that switch when doing so. I reset it and everthing works like a champ.
The issue I now have is that, before noticing the other valve/switch issue, I had removed the post-filter actuator and valve top to see if there was a problem with it. It, of course was fine and I replaced everthing but I have been unable to get a really complete seal on the valve now. It's not a large leak.....really just a pinprick size. I can still run everything fine but I do need to fix it at some point.
I think that the issue might be that when I removed the top, water continued flowing out of the top of the valve (pump was off). I'm wondering if the water pressure pushing upwards when trying to seat the valve top down is preventing it from getting a completely good seal. I let the water flow out for a little bit thinking that it might just be draining out of the piping between the filter and the valve but it really never slowed down.
Do you have any suggestion on how to stop the water from flowing out so that I can get a good seat? I tried different multiport settings but that didn't seem to have any effect. I pulled it off and reseated it 3 times but had the same issue each time. BTW.... there was no gasket or anything between the two halves, which surprised me. Just the two hard plastic surfaces. Is there supposed to be a gasket of some sort?
Thanks again for the post as you definitely know what you're talking about!
