eric99gt
19 -
eric99gt's Achievements
Just for reference. You can see the spa in the picture. The hole is where the red circle is drawn. This hole fills with water.
I've been through the myriad of potential sources. I first thought it was drainage, but even when I would empty the hole it would return pretty quickly. I could see it actually flowing in to it. Given the fact that the water in the hole contains the same salt concentration as that in the pool I would deduct that the water is coming from the pool. By the way still no solution.
Is there anything specifically that you are referring to? I've read through the majority of your tutorial (very good by the way) and don't see anything that would really help me in my case. Many of your methods for determing where the leak is originating will not work as the pool just doesn't leak water that fast. By the time anything would be noticed in the level of the pool it would have surely rained and replenished that loss. I'm talking extremely slow leak. If it wasn't for the wet ground I would have never noticed it. Maybe one day I'll have it fixed...lol. Thanks
So it's getting a bit old paying $140 every month for someone to maintain my pool. I'm pretty competent and pretty sure I can tackle this myself if I had the knowledge. Is there any good guides out there written by members here or somewhere else that can start me on this journey? Thanks
Well it looks like I'll have to hire someone else. First guy was a flake and now no longer responds to phone calls. Sometimes it's better to pay the higher cost to start. Already confirmed it's for sure coming from the pool. Exact same salt level as the pool. Now I just have to find it. The flake said he checked the pool and spa light conduits and they were fine. I'm skeptical of his results though. We'll see. Found a review of his online after the fact where another customer had the exact same experience. Came out once, made a few minor grout repairs, and took off. Leak not fixed and never to be heard from again.
It's a minimal amount. Not even enough to notice until the next rain. But I know for sure it's a leak from the pool. I only found it due to a wet spot in the yard and have dug up that area to find a hole that continually fills up when I empty it. Also I've tested both the salt level in the pool and the hole I dug and sure enough the same concentration of water exists in both.
Well it looks as if you were spot on. Sure enough it is indeed a umbrella holder. As for the drains. Mainly I was concerned with if it's likely that they're tied in to the drains for the pool. As such I was thinking if I plug up the ones in the spa I'll still have water entering the line I think is leaking from the pool. This would negate my attempt to determine if the spa drain line is the leaker.
Holy crap. That does look alot like what I have. I'll mess around with it tonight and see if I can pull that cover. Can you explain a bit more when you say spa suction line vs a jet suction line? I notice I have two what look like drains in my spa. One on the side and one on the bottom. Is one for the jets and the other just for debris and to drain the spa? BTW pool clown. Thanks so much for your advice during this ordeal. I may not be fixing the problem but I'm learning a lot. Also I caused another slight issue. I was screwing around with a valve trying to figure out how it operated (automatic valve) and i slightly damaged the mating surface for the cover while prying it up to get inside to see the valve. I'm thinking just throwing some teflon on there would fix the issue as it's just a weep of water that's escaping. Good idea?
Well good news on the ring front. Found it. Pool guy came over today and by adjusting some valves was able to force the ring in to the pool equipment. So at least I can stay married through this ordeal lol. Bad news is I still have a leak. Is there any way to plug up these main drains in the spa to confirm whether or not the water is indeed coming from there or would it also require me to plug up the drains in the pool as well? Are they all interconnected?
Quick question, How long are you waiting between the time you empty the spa and you decide that it's still leaking? I ask because it could take several hours before the water would stop fulling up the dug out hole depending how close the hole is to the leak. It's been various times. I've done it for like a day where I've had the level of the spa drained all the way to the floor yet water would still fill up that hole.
tell me about it. and sure enough I go out this morning to get some stuff from the garage and notice the pump is on yet there is no water circulating. Could my ring have gotten all the way from the drain to the pump and caused a blockage? I pulled out all the valves just to be sure nothing was blocking those and they were clear. Does pool ownership ever get easy?
No, I did not mean that your high water table is the issue. What i was suggesting was that maybe your pressure relief was not sealing correctly anymore and that is where your water is coming from. The fun with this pool never ends. Last night i'm chilling in the spa and being the fidgety person that I am take off my wedding ring. Well since I wasn't in the most sober of states I dropped it. And of course it goes right down the main drain. Doh. So this morning I get to work draining the spa to pull the cover on the drain and search in the hole. During this process I had the spa level below the PRD with only the main drain being full of water due to its connection with the pool. Sure enough hole still filled up. I'm betting it's that main drain. And no I never did find the ring. Hopefully it turns up in a basket filter somewhere but I doubt it.
Ya i'm quite sure it's not a high water table that is causing my issue as I did some testing on the water in the hole and confirmed it was indeed pool water. But that doesn't necessarily mean that the cover on the bottom isn't a PRD.
Contact one of the larger pool service company's in your area. They have a relatively new breed of pressure testing equipment attached to a video monitor. Not only can they tell you that there is a leak, but they can actually show you exactly which line is leaking and the exact location of the leak. If the first spot you noticed is in a direct line from the pool to the pump, usually a return line, that's probably the problem. However, the days of guessing are over thanks to this new equipment. I already paid once for a "professional" to come and look for the leak. I don't know if I want to go down the route of paying someone else quite yet. Really what I'm looking for before I go any further with trying to get my money back from the original leak detection guy or to move on to someone else is to ensure this truly is a leak from my pool. As in it's not from a sprinkler system/high water table/ someone elses runoff. Is there some sort of test I can do on the water in the hole I dug that will confirm this truly is the pool water? Thanks again BTW. We did pressure testing of the entire pool. All the lines held fine. So I have doubts that adding a camera in to the mix would be any help. Well still no solution. Still have a leak even after having the leak detection guy come out 3 times. It's getting really frustrating. The leak is extremely slow and it seems as if once the water in the hole reaches a certain depth it stops filling it up. Maybe someone can help me with the picture below. The expert has no idea what this is and was thinking it may have something to do with it. I'm referring to the metal cover at the bottom of the spa circled in red. Zoomed in on the second picture. Picture in the link provided. Also any other thoughts are appreciated. I'm really running out of options here. Pool
