Hey Guys...
I have a older RayPac 250,000 BTU Nat Gas Pool Heater that's still working like a champ, these are well made simple to operate and simple to maintan. It uses a Honeywell Gas valve and spark igniter. We live in So Calif and seldom used the heater for our pool and we just installed an above gound Acrilic/Fiberglass Spa and Pump, the new pump and old heater are seprated from the pool water.
The heater works great just as it is supposed to, however when it reaches a temperature of about 98 F., it shuts down and won't relight for about 20 mins. We would like it to reach atleast 103 to 105F with the Temp Control set to max. I have checked and cleaned all the terminals and wires with a voltmeter, all is good.
Does anyone know if there is some internal limitation on these old RayPac's that prevent damage from overheating? Or could the Temperature Control and Capilary / ThermoCouple need replacing? The unit is not on a timer and we just simply use the heater 'on demand' and shut off and disconnect power after every use. Would it make sense to possibly cut the brass ThermoCouple / Capilary Bulb off the back of the Temp Controller so it does not shut the unit off? I have attached a photo of the Temp/ Control.
Thanks,
Scott
