I do turn it down to 80 during the week as I work long days and pretty much (unfortunately) only use it on the weekends. Also, this has not been an issue in the past where the tub would be pretty much equal with the ambient temperature and not 30-40 degree above when in either the sleep or economy mode and setting the temp at 80.
You may want to consult the manual for your specific spa and see how they explain how their "sleep mode" is designed to function.
Really though, if you've set the temp to be 80F, and it's actually 95 to 100F, you could have a bad thermostat in your spa.
If your spa water temperatures were reaching ambient (50F?) while in sleep mode, it's not insulated very well. If it only shuts down the heating system for 6 to 8 hours, and drops from 80 to 50 even, the spa can't be very heavily insulated. If it has in fact been dropping that far in water temperature during its sleep mode, you're probably creating a higher electric bill than you need to.
It's likely cheaper just to maintain a steady temperature than re-heat all that water every single morning when the spa kicks back on.
Its never gotten below 60 in the sleep mode (Not clear writing on my part) I was just saying 50 since that was the outdoor temp but the spa is staying at 95-100. I will verify with a second thermometer if the water temp is the same as the spa thermostat to rule out the possible thermostat issue
