Howdy,
The osonator on our spa has a gurgling noise associated with it. It goes away after several months, but when ever the water is changed, the noise returns. I was told to make sure to bleed the pump which I did but no help.
If I remove the line from the big in line T and block the suction side, the noise quits right away. The water flow continues with no air introduced so I am guessing it has nothing to do with air trapped in the water pump or line.
Why it goes away after a couple months of use I can only guess.
Any suggestions would be welcome. By the way, the unit is 6 months oldn and has had the noise since the original start up and thought it was normal. Its only when it quit, which was so nice that we discovered there could be an option to the noise.
Down East Cape Cod model.
Thanks
