How do you all deal with your hot tubs when going away for a couple of weeks?
Assume not possible to have someone come and take care of it for me (always possible I guess but certainly inconvenient).
I was thinking one of two approaches:
1) Superchlorination before leaving and super chlorinate upon getting back. Thought is to get chlorine level high enough initially and with no use it should be good for a week or so. Then on getting back blast it again as a sort of mini decontamination.
2) Drain it and leave empty. Thought being I'm due for a water change anyway. Problem is it will definitely be cold enough to freeze any residual water in lines here during mid November. How do you get all water out of all lines? Is a shop vac powerful enough or is compressor needed? If shop vac then suck or blow? Drain lines or jets?
Unless I hear otherwise I'm thinking combination of the two - i.e super chlorinate now and drain when I get back. Any other suggestions?
My basic info - Jacuzzi 380, 550 gal hot tub, using dichlor/bleach.
