I have searched this wonderful forum, but I am not quite seeing the answer I need.
I have 2 commercial pools (at a guesthouse).
The problem pool:
9800 gal in ground
D.E. filter (with a couple of torn grids)
Almost all chemicals come from In The Swim
pH and TA are usually within tolerance
I test with Taylor test kit and strips.
This pool is in pretty good sunlight all day. Florida Keys (nice and hot). Summer heavy rains off and on. CYA is almost always high >100
The problem:
Early in the summer I started seeing yellow algae and began using an algae product (Super Algacide) from "In the Swim". I did it every week and there was no affect on the algae. FC was kept between 1-6 ppm. The pool service I was using at the time said I should shock, which I did, but it was never enough. So one day he said, use 4lbs of shock and that should do it. It did, for a while. It also raised the FC to over 20 ppm. I closed the pool until it came back to 10. But the algae came back a few days later. (BTW, the shock is 73% Calcium Hypochlorite)
I would routinely put 4-5 3" tabs of stabilized chlorine, chlorine shock once a week and non-chlorine shock once a week. I would brush the walls nearly every day to keep the algae down, but it would never go away.
Then a strange thing happened. TC and FC got to about 15 ppm and the CYA was around 100 - 150. I stopped putting tabs in the chlorinator, and the chlorine never changes! I know this is probably due to the high CYA, but I had not put chlorine in the chlorinator for well over 2 weeks.
Then we had several days of heavy rain, so much so the pool was close to over-flowing. I thought, Finally, the chlorine and Cya will come down a bit. Levels did not even budge. I am still not adding any chlorine.
I know the only solution to the high CYA is to do a partial drain, but my big question is why does the chlorine never change over time? It is so confusing.
All help gratefully appreciated.
Thanks,
Lorraine
