I was hoping someone might be able to help me out on a balancing issue. I have a new Bullfrog Spa. The manual indicates to adjust Total Alkalinity to 125 - 150 PPM. My initial TA test (using titration method) indicated TA of about 60 PPM. I used Alkalinity Plus (sodium bicarbonate) to raise the TA to the 130 - 140 PPM range. pH testing (phenol red method) then indicated high pH of 8.2 or higher. I began bringing down the pH with pH decrease (sodium bisulfate) and when I finally got pH to Bullfrog specs of 7.4 - 7.6 Total Alkalinity was back down to about 60 PPM. It appears that pH and TA track proportionally but how in the heck do I reach my target levels and raise TA without raising pH or lower pH without lowering my TA? I attemped to raise TA again and pH shot up too! Very confused!
FWIW - I'm using granular sodium di-chloro as my sanitizer, an occassional non-chlorine shock (potassium peroxymonosulfate) and calcium hardness is at about 200 PPM
One thing I noticed is that test strips tend to vary wildly on TA levels. While my HTH titration kit indicated TA of 130 - 140, I tried using both HTH and Clean Water Blue strips and they indicated much higher TA levels???
Thanks!
