Hi all... I have a new error code that I've never seen before, #113 & 114 on my ClorMatic II 601 Plus. Based on the manual the order of troubleshooting is to first clean, then replace the FLow Sensor. I've cleaned the flow sensor already and still no luck, so next step, based on the manual is to replace the sensor. At over $200 for a new sensor, this will be an expensive test. Is there a more acurate way to troubleshooting, or am I stuck with the "replace each part until it works correctly" method (flow sensor, then back board, then front board)?? Thanks for any help you can give me!
