On the main display window in the unit
The numbers you see are a average reading, if you press that little black button 5 times until you see a negative sign - then a number that is the current salinity. At 4100 the machine will shut down generation because it is to high and start flashing lights.
If you put the machine in super chlorinate it should force the cell on. Now press the button again all the readings should have numbers no zeroes. A correct cell will display about 23 volts and pull 3-6 amps.
here is a link to the manual on page 17 explains the button sequence.
http://www.haywardnet.com/products/manuals...s/Manual239.pdf.
If you salt reading is really at 4100 the only way to lower it is two drain some water and refill with fresh.
If you never get a current reading while the generating light is on, you have a bad cell.
I will see what happens when I put it in super chlorinate and leave it there for a while -- I do know that the instantaneous salinity number shows zero also. I have been thinking I might need to drain and refill to get the salt level down. Thanks!
