I have an above ground spa that uses 220v. I was gifted a working Pentair-Minimax Heater 100,000 BTU Pool/Spa Heater - Natural Gas. The heater has a inlet and a outlet. I am thinking that if I turn the heater temp down and run the pipes to my gas heater it everything else should work the same. I have idenified the heater and below it almost connected is the pump for it. I am not sure if the water flows
Drain - - Heater --- PUMP
or
Drain - - PUMP --- Heater.
What part on the heater is the inlet and the outlet?
Where do I hook up this to the spa and bypass the 220v heater?
Has anyone here tried this before? Gas is cheaper then electricty.
http://www.swimmingpoolsetc.com/pdf/minimax-ch-manual.pdf
http://www.swimmingpoolsetc.com/PEN-460347.htm
