Hi, (hope this is in the right forum)
We got a used Dreammaker X-Calibur spa from a friend my in-laws ... can't beat the price! We brought it home, used the tool to remove, clean, and inspect all jets; then set it up and used it quite a bit from Oct 07 to Feb 08. Just before we stopped using it, the side we used most often started making a "whirring/gurgling" noise when we opened the venturi valves (hope that is what they are called); the other side worked fine with no noise and when the noisy one was closed there was no noise. We stopped using it as it got a little warmer and I was going to fix it right away.
Fast forward 5 months and woodworking and my motorcycle has earned far more of my free time which is not much anyway with 3 1/2 and 4 1/2 yr old daughters. I would like to get this figured out and have done some net surfing, and looking around in the shell with the panel off ... I'm hoping someone could give some pointers are where to start. I'm pretty handy with many things mechanical, electrical, and plumbing and a little bit in electronics. I had not even realized that the plug had been pulled out and no one knows who did it or when so as you can imagine the water is a little funky ... a slight greenish tint. I plugged it back in and currently it is running to get the temp back up to 100 from 84 during its initial power on cycle. I wasn't sure if I needed to drain it below the jets before taking them apart to check for blockage, air leak, etc. My first inkling was that there is some sort of air leak from one of the fittings on the venturi valve, manifold, or jets. But now the noise is present when using the other side valve as well ... has me wondering if there is trapped air or something else. I know it was not smart for us to neglect the poor thing but that is in the past now. Hopefully we can get it back up and running right soon and will drain and refill and put new chemicals, etc. I guess there may be some sort of flush that needs to be run through it to clean the funk growing in the pump, pipe, etc. Spa information and images provided below ... any assistance is greatly appreciated!
1. Dreammaker X-Calibur, ~2004
2. Plugged into outside GFCI outlet (only thing using outside plug on regular basis)
3. Control box is labeled Balboa LB70 ... couldn't find any info on Google.
4. Topside control is electronic.
5. Pump: Aqua flowmaster 110v model: 03510631-2 ... no info on Google
6. Thermostat: pushbuttons on topside control
7. Heater Type: Thermix 52B thermal wrap. ... no info on Google
Misc pics:
